2016 eco injector replacement
farmer63
Hello all, just ordered 6 new Bosch injectors for a 2016 eco diesel as the originals were out of specs. Way off. The Bosch dealer said they don't need to be recoded on my scanner. I am under the impression they need to be. What's the right answer? Thanks Robert
727
WOW.... what do you mean by Way off....More like you were Rip off...
farmer63
1 zero output, 3 less than 40%, 1 at 80%, 1 at 85% from the report.
727
What report....never seen a report on Output levels....
Tmckinney20
142
63
I have to agree with TC. Sounds like they got you. Can I ask what you are out? $$
farmer63
$1500 for new Bosch . no charge to test when I bought the new ones.
farmer63
This is my last eco to get rid of. Had 3. Ran good when they aren't broke down, good mpg. They were the biggest POS I have owned. Had hard start and stall. Pressures from newer tank pump good , rail pressures good on turn over rpms. HPFP quality solenoid clean, no metal. If injectors work , it will be for sale that day!
727
0 445 110 522 OEM Bosch New , 0 986 435 251 House remans.
farmer63
Installed today, she if it runs tomorrow ! Have not recoded the ecm for the new injectors.
