2016 knocking/exhaust noise, low oil pressure
demj1308
2016 with 140k miles, starting making a noise last night sounding like a knocking or exhaust leak. went to drive it next day and when stopped at light got low oil pressure warning, took it home checked oil and was a little overfilled and i noticed oil leaking on ground, got under the truck and it seems oil is leaking from front area of motor. Anybody have any ideas ? if its something major probably going to just trade it in.
Thanks
Tmckinney20
142
62
I had a leak on the the front timing cover. Dealership repaired it under warranty. Said it was fairly common. Probably the leak/drips you are seeing, but I have no idea about the oil lamp or knock. I would be curious to find your much needed answer.
