2016 ram longhorn Laramie eco diesel
David7231
When truck gets to half a tank of fuel
loose power ,engine shuts down engine light comes on ,service electronic throttle control, oil pressure flashes.
I read this is happening to other eco diesel trucks I cleaned map sensor still happening.. Any suggestions truck started doing this at 35,000 miles still the same at 80,000 miles
1,068
367
Sounds like something with the lift pump is acting up. When you run below half a tank, the hot fuel coming back from the return line dumps on top of the pump causing it to over heat.
