2018 Ram 1500 Laramie coolant leak
skulls2025
Joined
Jun 28, 2025
Messages
I have a 2018 ram 1500 Laramie V6 diesel. The coolant reservoir empties out but I do not see any coolant leaking anywhere when I refill it. The hose on the bottom has some bubbles. The dealer service dept could find no leak, but recently the the overheating lamp came on still no apparent leaks detected, but there must be a leak somewhere. The turbo was recently replaced by the dealer. Anybody got any suggestions?
Likely suspects: Turbo coolant tube under intake or EGR cooler.
The turbo coolant tube is two metal tube connected by a clamped rubber hose and is prone to failure. If you end up replacing it, there is an upgraded one-piece line with steel braid over the rubber section available.
Also, check for leakage from the small, black, plastic tube just above the water pump pulley and below the air hose going to the throttle body/intake manifold.
On my truck, there was a small leak on the bypass pipe on the top front of the engine. It is a small pipe with seals on each end of the U shaped pipe. I found the pipe for around $20 on Amazon once I saw that it is a very small leak. Other possibilities are a leaking eater pump, turbo coolant hose, and the 3 way water valve. But if it is hard to find my vote would be the U shaped bypass pipe above the water pump.
