2020 ram how to check, change antifreeze
case310350
have a 2020 ram. Was going to change the antifreeze in the truck, found there is no petcock to drain radiator. also notice the lower hoses had no fluid in them so now concerned. is there a way to check antifreeze level other than looking at the reservoir? How do you drain the system, where is the petcock?
SeanPwnery
157
75
Fast forward to about 3 minutes and 54 seconds, I did the heater valve and show where the drain is for the rad - it's on the driver's side. Hopefully it's the same on a '20 as it is on my '16 since the radiators seem to be 2013-2022 listings.
case310350
thank you for the information. should be the same. Not much info on the eco diesel. yet.. not sure if i should invest in the service manual.
