SOP
- Dec 11, 2017
- 48
- 11
- 2014
I’m trying to figure out if my battery is due for replacement. I’ve got a 2014 so it’s over 4 years old. The dash reads 12v prior, and then 12v post startup for 10-15 seconds, then reads 13v. My Edge CTS 2 reads 13.8v once running for a minute . I tried to search around and couldn’t find if that’s a normal reading or not.
Since it’s a sealed battery I can’t test the acid... which is the only real way to know if a battery is good or not. Unless it should be reading in the 14-14.4v range while running?
All connections are clean.
