Camion ne start pas
Chakib
Salut mon camion ne start pas les glows plugs ne chauffent pas , est ce qu'il ya quelqu'un a eu le meme problem merci
1,053
363
Podría ser que el módulo de la bujía incandescencia es malo
(It Could be that the glow plug module is bad)
willypeters124
13
Yes everything ok
Ok if it cranks and does not start then I would check the plugs that are under the front left fender. There are a few so just check all of them. I had the same problem and it was a very simple fix.
1,053
363
Could be a failed tone ring also, there is a couple different recalls for them depending on your year. No codes? Could be a variety of things really like Jacob stated check all your plugs and connection's. Make sure battery is good and check all fuses. But the tone ring failure will also cause a no start and is a fairly common issue with the ecos.
willypeters124
13
There seems to be a few things that cause this problem. The first time this happened I replaced one injector. The second time I found the problem with the connections by the fender as explained.
