Caught fire driving down the road. Guess i am not the only one.
717
The sound foam should be removed for rodents and visual inspection....It also is damaging to all the components it smoothers. Both sides of the engine foam and CP4 cover. Also the Foam is always in the way for cleaning and repairs.
Only reason this garbage is use is to lower the sound,,, IMO you should NOT own a Diesel if sound a concern. Removed Sound insul 3.0 ecodiesel.jpgEcodiesel 3 0 - Copy (5).jpg
Gern2469
And They have been investigating since may2019
  • RMISC-19V757-6098-1.pdf
vwvanagen789
21
Only reason this garbage is use is to lower the sound,,, IMO you should NOT own a Diesel if sound a concern. View attachment 2369View attachment 2370
Thanks for the heads up. Was there any noticeable drop in temps with removing the foam insulation ?
k
954
492
Removing all of that foam was one of the first things I did to my 2016 Eco.
For all the reasons TC said, especially the ability to see the engine at a glance and keeping it clean.
Back in 2016, the pundits came up with all kinds of ridiculous reasons why removing the foam was a bad thing to do. I've not found anything but good for removing it.
