check engine light and tpms
dickeyphoto
Check engine light as well as low tire pressure indicator came on, on the way home from the dealer, bought used as is. The message says Service Tire Pressure Maintenance System. I checked the tires and put them all to 40 as specified inside door panel and two tires do not read at all and the others read 42 and 38.
Any thoughts?
As well, can someone tell me how to read codes as well as reset them without taking it in or buying an expensive diagnostics tool? Will the codes generally come through the messages log?
On a good note, this truck is amazing!
DieselDude
55
Welcome. ive been to the autoparts store once and it worked well. just wrote down the code and googled it when I left.
