so a few things wrong with the fuel filter procedure,I've made a bunch of videos for work. I'm planning on doing more as I add miles to the truck. LMK if you have any requests/recommendations.
1.) book states to cycle the key with the Phillips drain open to drain without having to open it and break the vacuum. (I have not done this yet for a filter change so I'm not positive how thoroughly it drains and I have a solid drain plug also..)
2.) But when you prime the system you need to wait until the pump completely shuts off, not just changes tone showing fluid load, and you should be cycling the ignition doing that 3 times or better. It's in the owners manual.. only one time does not prime entirely especially with a filter change and not just a water reservoir drain
