CP 4 PUMP ARTICLE
CAVEMANN
388
129
This is a good article on the HIGH PRESSURE FUEL PUMPS used in the ECOS and several other diesels.
711
The ways listed in article are lacking. I have CP4s that have 500K miles Without the so called fixes listed.
The CP4 is a particle maker when it starts to fail.
I wonder if CARB is aware the 9th Injector pressure on the CP4 Body port (Duramax 2011-16) is considerably higher than the CP3 return port. I have never tested the 9th Injector so I would have to investigate to confirm it works or Not. Most conversions consist of Competition use which do away with the 9th Injector.
