Diesel additives
Korsch
I’ve tried searching around the forum and really couldn’t find much on my general question.
Im curious what’s good to run in these EcoDiesels for getting water out or for keeping the diesel from gelling. It’s a cold night tonight (-36 C) and I’ve never ran any in my EcoDiesel because I’m not sure if there’s anything special for these engines.
Thanks.
284
nothing special just get some from Walmart they have a variety
Will_CathVT
77
24
Same here, I understand Tractor Supply has a gallon of treatment for less. I need to look into it.
KnowFear
IMHO... Stanadyne Diesel Fuel Addative is the BEST! I buy it on Amazon.com. You only need just under 1/2 of a bottle at fill up since our tank is 26 gallons and a bottle is for 60 gallons. Every review site you find will have it at the top!
JimmyD74
Just curious, but will putting any type of additives affect the warranty?
941
486
If the additive caused a problem they probably wouldn't fix it under warranty but it should not affect the warranty.
That said, I have never heard of an additive causing a problem.
Will_CathVT
77
24
I live in Vermont have been adding fuel treatment for a couple of months and haven't had any issues with performance.
klinder
Thanks.
Secrets diesel additive I have heard works well. I just bought a jug for $120 CAD. I will try and find the guy that did a you tube video on several diesel additives. Go to you tube and put "Diesel Fuel Additive Test" in the search bar. It is a good video if it all the information is true.
941
486
klinder
Here is another one to watch as well incase you didn't know. "Should I Delete My Diesel? The Truth about Diesel Emissions"
danfill
Thanks.
I’ve had really good results with the Justice Brothers Diesel Anti Gel. I’ve ran it in my Duramax & ecodiesel. No issues, it even improves the fuel efficiency.
CAVEMANN
388
129
I found an independent test several years ago and IIRC OPTI-LUBE XPD came out the leader of the pack.
941
486
That test only measured lubricity and bio-diesel was #1, Opti-Lube XPD was #2
  • 02a-2007 Diesel Fuel additive test.pdf
CAVEMANN
388
129
I think that 's a different study, IIRC the one I found included HOT SHOTS DIESEL SECRET, this was before they had the EVERY DAY DIESEL TREATMENT. It also contained pictures and specs for the high pressure(HFFR) wear test. I've been looking and can't find it, I typically save stuff like that, but apparantly I missed that one.
941
486
Gotcha - thanks
