Does anybody know what WC90 code means
Freedom319
30
Why when I do an oil change on my 2022 ram ecodiesel I low pressure oil light on
I’ve not heard of nor could I find any info on the WC90 code. Also, make sure whomever is doing the oil change is using the correct oil and putting in enough quarts. Diesels use more than gas. I realize this is a simplistic answer so no insult intended, I saw your truck is a 22’ so wanted to make sure you knew.
Tmckinney20
142
62
Man you have a warranty. Take it to the dealer. Don't try to fix it. You will have plenty of time for repairs when the warranty runs out. Plus you do not want to risk the dealer canceling your warranty because you or someone messed something up. Not saying you did, just cover your butt. The dealer covers theirs. Just my opinion.
Armando Suarez
I already took it to the dealership and the code they put on the receipt was P0524 the said everything was fine cause they checked it but the light still coming on
Tmckinney20
142
62
Sounds like you found an incompetent dealer. Go find another one. Make sure the lights on when you take it.
