Driving and truck shuts down to limp mode
pcravens
25
Was driving and the Eletronic Throttle Control came up. Pulled over tried a few things but no change i did not have my scanner with me. I limped back home and parked it for 2 weeks. Got back home and pulled the codes P26A7 Engine coolant Bypass valve 1 position sensor circuit high , P2683 engine coolant bypass valve control circuit high , Po12D Turbocharger inlet pressor circuit high , P2455 Diesel Particulate filter pressure sensor high -pending , P2681 Engine coolant bypass valve control circuit open-pending , and U1428 Inaccurate Engine Torque received , Ok i cleared all codes truck starts up and is running fine go about 5 miles and then it does the same thing. Where do i need to look first something is triggering all these at the same time , i just dont want to start replacing a lot of parts. Thanks for any help you can give me or point me in the right direction.
pcravens
25
just pulled MAP sensor and EGR cross over pipe both in good shape very little soot on crossover pipe and MAP was clean
