Dwight
Dwightsram
With the problems with the eco diesel. Why is there no fix or preventive maintenance?
BTdriver
115
47
There are things you can do to reduce the chances you are affected by these problems. Generally, changing the oil at 5-7k mi instead of 10k per spec, is advised. I also use Lucas synth oil stabilizer for added protection. Getting a tune on the engine and trans will help it run cleaner (and get better MPG) reducing soot related problems. The CP4 injection pump needs a lubricity additive to live longer. There is an aftermarket upgraded pump available - CPX. Installing a "disaster prevention kit" will save your fuel system when the CP4 eventually fails. It reroutes the fuel lubricating the pumps cam and rollers out of the pump, through a filter and back to the tank instead of sending it to the injectors.
That's all I can think of at the moment.
4,339
1,146
Welcome, plenty of problems sadly, but also some preventive maintenance that is known to prolong the life of the motor. I would advise reading some of the forums and learning more, we've got a lot of good and knowledgeable members here.
