EGR Recall
Theo Breimer
So I received a letter today from FCA advising that the parts are available for the EGR recall and urging me to make an appointment. My only hesitation is I have a GDE tune which I'm afraid they may over-write with a factory tune when they do the recall. Has anyone else been through this and can you offer any suggestions as to how I can prevent the dealership from flashing the ECM back to factory settings?
I'll appreciate whatever advice that can be offered...
Thanks,
1,051
424
You could lock up the OBD port or talk to your service manager and ask not to flash. But there are no assurances even with good communication. If I were in your shoes I would program a backup ECM to use for dealer visits if you don't want to lose your GDE tune.
I'm assuming you have an older tune because with GDE's latest offering you can switch between stock and tuned with the programming tool so no worries there.
905
371
I would ignore the recall before I jeopardized my 2019 GDE tune.
1.Many kept their stock ECM to swap out before dealer visits and then reinstall after dealer work done.
2.You could get the work done and trust them to follow your request to not flash. (kinda iffy there)
3.You could get the work done and IF they flash your ECM buy the new GDE tune.
Theo Breimer
Thanks for your response. I have an older engine tune where they sent me a reprogrammed ECM and I returned the original, but the transmission tune that I got a little later included the programmer. I don't suppose it could also be used to reprogram the engine tune could it?
1,051
424
No I don't think that'll work. You may give GDE a call and see if they would discount a new tune seeing how you are an existing customer. Before the EPA neutered them, it was only $50 to reflash the ECM if it was ever written over. Not the case anymore, but GDE may work with you, not sure.
4. Find a used GDE tuned ECM if yours gets flashed over.
Theo Breimer
Thanks for your help. I did contact GDE and they pointed me to a tune update for existing customers on their website. it's still $50 for an update if the dealer reflashes.
1,051
424
That is great news. I thought it would be higher than that to update. Although it won't be your same PRE EPA tune, I've read good things about their current programming.
Theo Breimer
Actually I checked with them and they confirmed that since I'm in Canada we're not bound by EPA and I will in fact get the original tune.
TooClose Racing
24
My dealer says that I do not have to install the new software updates (ie AIM #2 FIX) when I do my EGR replacement. I'm waiting for updated EGR to arrive to schedule my appointment. She said the only downside is that I will continue to get reminders from Chrysler about doing the software updates. By the way, I was informed that there is a parking gear/indicator safety recall. Has anyone had this done?
Ecopete
166
I didn't get the software updates when I got my egr recall done, and I also declined the park recall. That's for when you open the door while in reverse it automatically selects park so you don't run over yourself!🤪
jsasada81
17
14
Got my EGR recall done yesterday. Have the EPA GDE tune. Put back to stock before I went in. Put back to GDE as soon as I got truck back. So far so good. No issues.
Dealer was really awesome about it. Service writer said they needed the truck all day and he put me in a 2020 Ram 1500 Laramie loaner truck.
I dropped it off at 7:30am and he called back at 5pm that afternoon and said it was ready.
Work order states the following parts were used:
CSNDVB12AA - EGR Bushing
CSNDVB11AB - EGR Cooler
68163848AB - Coolant
4,345
1,150
Good to hear it went smooth!
