XTHEGodfather63
- Feb 9, 2023
- 1
- 0
- 2016
Hello,
4 days ago I got in my truck and it wouldn't start. No check engine lights come one but the screen did say "Service Electronic Braking System, Service Electronic Throttle Control, Service Transmission Continue in D. Do not shift or turn engine off until you reach a desired location. You may not be able to shift again until serviced.
But the truck wouldn't turn over at all so I called a tow truck and took it to local CDJR dealer. About a month ago I took it to the same dealer and they serviced my recall for the EGR issue. Once they took a look at it they said they didn't see any issues except that i had a software updated needed. They updated it, test drove for 10 miles and it started up multiple times. I drove it for 2 days and tried to start it up today and it would not start again. But this time a check engine light did come on. I used my wifes car and got a EDO reader. Came back to the truck 4 hours later and tried to start it, still wouldnt work. Put the reader in and ran it. Truck started right up. Did have these two codes pop up: B1479-13: Channel 6 Audio Speaker Output- Circuit Open & P1E0C-00: Empty Fuel Tank.
Truck was filled up to full tank after picking up from dealer a few days ago so its not empty and DEF is half full.
Started truck up multiple times in 30 mins or so. Drove it, ran OBD multiple times still same issues but truck will continue to start.
Im asking if anyone else has experienced this and or know about it, really don't want to go out and doing something then come back to the truck and it deciding it doesn't want to start.
