I have since decided that extended drain intervals are not appropriate for this shit engine and so the added expense of a bypass filter system would not make sense.
Boostn the ecodiesel has won a plenty of rewards, plus Gale Banks loves the engine and uses it for military projects. After many years in the motorcycle industry stock stuff is usually very reliable. It's when people screw with stuff that typically causes the problem! The very few that have gremlins are the ones that make the most noise. Any emissions laden diesel makes me question the longevity. I hope to get Banks to address the longevity question!!How many miles are on yours? Have you experienced a lot of problems to have that opinion, or just by reading the forums?
I would consider trading it in if you're unhappy, life's to short to keep something that you don't like.
My 16 Limited has been perfect also. The only things I have done is tried to get premium diesel at cenex when possible. I have 11k on Pooky (my truck, it was a smart A nickname my lil brother gave my Dad who recently passed). Oil changed at 2k to get break in oil out at dealer and rotella t6 went in. 9 k Amsoil sig series 5-40 went in and there was some nice improvements. 10.3k I put on a Banks cold air kit (filter and resonance tube) and that generated results also. I have always cooled down turbo, warmed it up before getting aggressive on the throttle. Every fill get Amsoil fuel and cetane treatment! I carry a bag in the box with the goodies in it! My wife calls it Pooky's diaper bag!! Yes there is what she calls its baby blanket in the back also to put under certain items like lumber so they don't slide around while driving. Yes I am just a little neurotic with it but I want it to last. Call Nick D at Banks customer service and he will hook you up! Tell him Scott from MN sent you. If I get reliability info regarding deleting emissions from Gale Banks I will post or provide a link! Drive safe! P.S I still have not went through a Regen cycle??Agree. I read the history of development. It's a NATO engine designed to jackrabbit around the East Front of Europe. I report no issues; perhaps as your suggestion Bootsn, my engine is still completely stock. To be sure, I've tested it - 15k+ pulling 7k Toyhauler so maybe staying stock is legit.
Is there a regen log in the computer to look this up? I've only seen white smoke once that I've noticed.You have went through multiple regens you just haven't had a dash notification.
They don't use much do they? I looked at the oil the other day and noticed it's black as tar so I am going to change it.
I have the same truck as you, 2016 Limited EcoDiesel. I bought it used 6 months ago with 11K miles. The ex-owner was a mechanic and probably knew about the potential problems to come. It now has 13K+ on it. It's had 2 oil/filter changes so far. The ex-owner put Pennzoil Platinum EURO L full synthetic 5W-30 in it. It is made from natural gas and is dexos approved specially formulated for diesel engines. It had 1/2 a tank of DEF when I bought it. I finally filled it at 1/4 tank. They don't use much do they? I looked at the oil the other day and noticed it's black as tar so I am going to change it. Should I go to Amsoil 5W-40 and start adding cetane treatment at every fill-up? Or stay with the Pennzoil and just add the treatment? I live in the PNW so it's usually a pretty mild climate.
Anyway, with all the doom and gloom about this engine on the forums I'm kind of freaked out about keeping this truck. I love it. It's like driving a Cadillac and I'd like to keep it. But it's a gamble, always in the back of my mind.
And just a side note. I heard about the GM/Fiat partnership on this Italian engine so I checked my oil fill cap. I says GM on the underside. lol.
Thanks in advance for any advise you guy's can throw my way, Mike, Issaquah, WA
I called Amsoil and the tech dept said to use the universal system. I need to find a competent shop / installer before I do it. I am comfortable doing most things but this is pretty critical to have it done right! FS2500 makes a kit but it's double the money!!
Have you done a full emissions delete also ( no def). What differences have you noticed? Engine temps, mileage? ThanksYes, the oil will turn black on all engines gas or diesel, however sooner on a Diesel engine. EGR (exhaust gas recirculation) is a huge contributor to the rather early visual pulsation of the oil seen in our Ecodiesel (and other modern Diesel engines) despite the large oil sump of 10.5 liters. I observed the same visual pollution during my first 3 oil changes that was done every 5000 miles, wherafter i had the EGR deleted (EGR delete by company GDE). After the EGR delete, my oil change interval has slowly been increased from 5000 to 7500 with fairly clean oil, even after 5000 miles. I had some oil samples tested and test confirmes all parameters well inside limits and even suggested to increase the interval, I will however maintained the 7500 miles interval. The Engine / truck has currently 62000 miles.
I agree with the amsoil system and great info!! I'm concerned with warranty compliance! I need to find a dealer that will install it and agree it does not violate warranty if there was a mechanical issue!The easiest way to install a bypass oil filtration system (Amsoil's is the best imo) would be to use the diagnostic port on the passenger side head for the oil supply. Or you could install an aftermarket oil cooler setup and use Amsoil's dual remote bypass system.
