Front bump stop issue
Green Flash
Aloha guy, as you can tell I'm in Hawaii. I have a 2023 Gladiator with the Ecodiesel engine. I love this truck only set back is the front bump stops had to be change already. I have never taken this truck off road yet, and the bump stops had to be changed, because of the weight of the engine.
The dealer gave me all kinds of lip when I took it in. They say I'm hitting speed table to fast. When their own tech could duplicate the problem at low speeds.
This truck will bottom out on the smallest speed bumps.
My question is, do any of you have the same problem?
I apologize if this was covered before on here, but I'm new here and Im still learning how it's done.
Thanks in advance.
966
349
First I’ve heard of that issue, sounds like when they designed the suspension they didn’t do a good job. When I added my leveling kit to my 2014 ram, I had to add a drop mount for my bump stops, but I don’t think I’ve ever come close to bottoming out on them.
Green Flash
Thank you for your response. I'm kind of bummed out. You would think engineers would take into consideration the diesel engines are heavier than the gas models
