GDE Purchased...Now What?
joseph73cf
Hey.
2015 Laramie. Just purchased the GDE tune today. When I purchased the truck three weeks ago it had the Banks Derringer tuner installed. Obviously this will no longer be hooked up. However, can I keep the Banks iDash hooked up for recording data? https://www.bankspower.com/series-2-idash-1-8-datamonster-and-supergauge.html
What other items should I consider upgrading for increased performance. I am not deleting as they are cracking down on compliance here in my area, so no deleting.
I am no mechanic, but want to understand and am willing to learn! I just need a point in the right direction :) Just unsure which things to swap out that will actually make a real improvement.
I am not currently towing anything. That will come in a year or two. Right now this is just my truck, and I am happy to have it!!
Thanks!
EARL99208
32
I'm no expert by any means, but I believe that the idash can still be left installed as a monitor.
BTW….do you have any plans for the Banks Derringer?
joseph73cf
I am going to sell it. I have a brand new iDash that isn't installed along with the mounting bracket that holds
I have since been told by GDE that you are correct, I can keep the iDash.
I will uninstall the Derringer and put it up for sale when I get around to it. I haven't installed the iDash yet. I purchased the pillar mount as well, but have not installed either. I may just sell the whole thing as a unit.
720
I would stack the Derringer with GDE tune, The Derringer at its lowest setting. You may like the results... Both The Banks Derringer/Bullet are pressure Boxes.
joseph73cf
I was not aware that you could use the Banks with a tune. Interesting.
What do you mean by "pressure boxes"? I am new to the diesel world and am slowly learning the language...kinda like when I became a Christian or when my father in law talks about his job @ the hospital. Everyone has a language that takes a bit of time to decipher and I need to eat two more boxes of Chocolate Frosted Sugar Bombs before I get my decoder ring!
EARL99208
32
Just let me know a price and what is for sale…. Maybe I’d be interested.
720
Pressure Box = Rail Pressure+ Duration.....Its the simplest and in most cases the safest within reason.......to Add HP to any HPCR system.
720
Earl if you don't buy 73 Derringer, I have the Banks Bullet I used for 3 Years in My 2015 3.0... The Bullet Does NOT use the OBD port , its plug and Play Rail Pressure and MAP Sensors. Makes the same HP as Derringer.
IMO like the bullet, it leaves the OBD port open for additional Monitor.
GoldenBear
Hey.
Thanks!
Hi Joseph,
I recently bought a 2017 Laramie and plan to do the same upgrade. I'd like a little better performance and mileage, but I'm hoping it will help in towing my travel trailer a bit better. My question is, was the update process pretty straight forward? I get by, but I'm no techy so I'm a little concerned about the process. Good instructions and simple process? Also, if I've read correctly, this shuts off and eliminates the need for DEF?
Thanks for your reply.
Orrin
joseph73cf
Hi Joseph,
Orrin
The GDE tune was very easy, even for me! The biggest challenge, if you can call it that, I encountered was using a PC! I have been on a Mac or Linux computer for decades and the Windows format takes me a little longer to work through. Once I understood how to use that, easy.
GDE sends you a hand held unit that you plug into the OBD port and it reads info about your truck. You attach that unit to your computer and create a file that you send to GDE via email. They email you back a file that you upload onto your handheld unit and go back to your truck and hook up to the OBD again and it puts the new file into your ECM and you are done!
This does not eliminate the need for DEF. You will still need to fill up. Some people hate the stuff. I knew going into getting a diesel that you need it. Not an issue for me. I've put almost 10k on this truck and still haven't added any DEF, so not a big cost as far as i am concerned. I understand if it goes bad that there is cost involved to repair, but it's no different if a headlight goes out....you gotta replace it.
Anyway, hope this helps. Very happy I spent the money on the tune.
GoldenBear
Thank you for the reply. I guess the part I was a bit uncertain about was how to down load and upload from the unit they provide. I'm thinking that will probably be more obvious once I go to do it.
joseph73cf
It is actually very simple. They have great instructions and if you have any questions they responded to mine very quickly. If you can figure out how to post on this forum I think you have enough brain cells left to to a GDE tune!!
GoldenBear
Again, thank you. I will be doing the upgrade soon.
