Getting REAL tired of 3-way heater valves...
SeanPwnery
160
75
Just a thought... the saying "The aftermarket provides" seems to have walked right past our little pasta-diesels when it came to these valves. Dodge wants 300 for a piece of plastic with a 6-pin sensor... kinda bonkers. The aftermarket options are 60 dollars or less, but ... as things have played out - I'm about to replace my 3rd one in 2 years. They drop right in, and I've got the replacement down to a half-hour job - but (rant begins) - how hard is it to get the sensor inside these damn things right?
I guess I'm just going to have to bite the bullet and get the OE one. In all honesty - this is the first time in almost 30 years of turning wrenches where the aftermarket failed to "do it better." :mad:
I mean... in all honesty - I kinda like it running at 185 degrees here in south Texas rather than into the 210's, but that's just my gasser side still being nervous about 2-hundred anything temps. I'm starting to wonder if maybe I should figure out what resistor I can wire in just to shut the ECU up like when I deleted the oil temp sensor on my T-bird after removing the garbage OEM oil cooler that failed. 🤣 (rant over... for now)
BTdriver
153
65
If it's any consolation, back in august of '24 I replaced my water pump and that little plastic tube that goes on it, then promptly drove to Las Vegas encountering 113°F temps along the way (from Colorado) and 110°+ while I was there - no overheating. Truck has SFT1 on stock truck.
