Guzzi Bill, new member and first time giving my $.02. On my 4th Ram, a 98 V8, '02 & '06 3500 dually's and a Dakota V6. Now I have a '16 1500 eco 3L.
Bill S
I purchased this after it had a catastrophic engine failure, a long block was dealer installed, and I took possession with 38,010 miles. It now has 89,xxx miles on it and I just had the necessary "flashes" to comply with the class action lawsuit. It's only been a couple weeks so I don't have much to say about the mileage yet, but I sure hate the flat spot/bogging just off idle. I darned near got run over by a dump truck coming over the hill when I pulled out of my driveway.
I'm also wondering what parts they will really warranty (I have the list they gave me). The extended warranty didn't cover the particulate filter(aka catalytic converter, $2,300 dealer) or the heater inside of the DEF reservoir ($1,800 dealer).
It will be interesting to see how it plays out.
It looks like those items are covered.
Consent Decree Appendix E
Extended Emission Warranty
Subject to standard limitations that must be identified to Eligible Owners and Eligible
Lessees, which may set forth exclusions like accident, abuse, neglect, or installation of noncertified parts, and applicable existing warranty provisions that will remain in effect, the
below.
• Catalysts
o DEF Injector
o DEF Injector Controller
o DEF Storage Tank
o DEF Delivery Lines
Cherokee only)
• Parts of the Fuel System
o Fuel Injectors
o Fuel Rail
o High Pressure Fuel Line
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o EGR Temperature Sensor
o EGR Cooler bypass actuator
o Oxygen Sensors
o NOx Sensors
o Fuel/Water Separator Sensor
o Particulate Matter Sensor
o Mass Airflow Sensor
o Boost Pressure Sensor
o Crankcase Pressure Sensor
APPENDIX E TO CONSENT DECREE
MDL No. 2777 EMC
Case 3:17-md-02777-EMC Document 484-1 Filed 01/10/19 Page 207 of 224
o Throttle Valve
o Exhaust Temperature Sensor
• Throttle Valve
• Cylinder Head Assembly, Including Valves, Springs, Valve Spring Keepers, Valve Seats,
Cam Bearing Caps, and Manifold Studs (Camshaft and other components of the assembly
are not covered)
Additionally, the Extended Warranty shall cover the cost of any OBD Diagnostic Scan
for malfunctions that trigger the OBD Malfunction Indicator Light (MIL), regardless of whether
the malfunction is attributable to a part that is covered under the Extended Warranty
Bill S
below.
• Catalysts
o DEF Injector
o DEF Storage Tank
Cherokee only)
o Fuel Injectors
o Fuel Rail
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o Oxygen Sensors
o NOx Sensors
MDL No. 2777 EMC
o Throttle Valve
• Throttle Valve
are not covered)
I will find out next week Wednesday when I take it back for about the 5th time for check engine light( particulate filter).
Well the list I provided is straight from the court ordered settlement documents so you can count on it unless your dealer is clueless. If that's the case you need to educate them.
