Help diagnose this...Coolant found when intake was removed.
slail29
Joined
Jan 2, 2020
Messages
Long story but here is the short version.
EGR was replaced under warranty but they found this(circled yellow in the attached picture) to be leaking coolant. They said it’s not the turbo coolant feed tube but rather a o ring that failed...Which isn’t covered under warranty. I hadn’t checked the coolant level in awhile, probably since the last oil change which was 2 months ago, opened the hood and it was low a half gallon.
1. What is it called?
2. How long should it take the dealer to replace it, they want $1800 on top of the repairs to the EGR which has the intake already off under warranty/recall.
Ive been thinking about leaving as is and trading but I’m worried they will bolt it back up and it will spew coolant so bad I can’t trade it.
thanks
