How to bypass a glow plug so engine light doesn't come on?
PA Steve
I removed my glow plug #4, and although I was able to remove the plug, the tip (the part that glows) of the plug stayed inside the motor. I realized this when I inserted the new plug, and it wouldn't go in far enough to reach the threads. I'm now getting a P0674 code for a faulty glow plug. I don't care about the plug, as the motor starts with no issues. What I would like to do is fool the diagnostics into thinking the plug is okay, so my dashboard light goes off. I measured the resistance of a good glow plug, and it is 2 ohms. I'm figuring I could put a resistor across the plug wires to fool it. Does anyone know if this would work? What size and wattage resistor should be used? Is there another method to accomplish this, such as programming?
1,063
364
Unplug the glow plug relay on the passenger side of the engine bay. Can’t remember which one of mine failed but it broke off trying to remove. Found that trick out and just a fair warning, if it’s below 35 plug it in. The colder it gets the more it hates starting lol
  • IMG_4797.mov
PA Steve
Thanks, I'll look into that as a quick fix. At least that way I only have to look at a CEL during the cold months.
MAShia
Hi Steve, When I was thinking of replacing all my glow plugs, what I found was crazy. The person who owned the truck before I did must have had an issue with glow plug #6 (a pain to get at and could not remove it), what they did was to detach the connector and take a new glow plug , zip tie it to something and attach the connector to it. Solving their problem. I have to admit I have had no problem with this plug (others yes, connectors failing yes). Food for thought.
PA Steve
Thanks for weighing in. I thought of that solution, but figured I would have to ground the plug, and then there would be a red-hot plug sitting on the motor. How did they ground the plug and keep it from catching the motor on fire?
