I accidentally put Regular gas in the engine!
Southernman0873
I was driving long distance and put regular gas in the tank. I drove about 150 miles at approximately 75 miles an hour until the engine died. I had it towed to the dealership. They have quoted me $12,500 to replace the entire fuel system. Please someone help me with some advice. I am in Jacksonville, Florida. If anyone knows a less expensive option I am open to advice. I really do not want a new vehicle although that option has been presented. It is a 2022 Ecodiesel. I cannot believe I did this!
autoX
86
Had a buddy who did this to his VW. He's a German engineer, PHD ;).
Shell in Canada has Bronze as regular, which looks yellow, like Diesel. So he topped 'er up and it died a short distance later.
All he did was drain the tank, refill with Diesel and cranked it until it started. Diesel circulates fuel (supply and return), so it will return fresh fuel to the injectors.
BTdriver
55
23
Most of the fuel system you could flush, but the high pressure pump is likely damaged and sent metal into the injectors. Those two should probably be replaced. The rest can probably be saved. That is, if you can find a mechanic willing to spend the time to flush stuff instead of wastefully throwing parts at it.
SeanPwnery
79
24
Since gas would easily detonate earlier in the stroke, you had to have noticed the pinging noises, the extreme drop in acceleration, possibly the CEL firing off. You honestly drove 150 miles without noticing anything??? The quote they gave you was definitely a full fuel system replacement - however you might want to be sure they compression test that engine before wasting any time on that fuel system. Pre-detonation will murder a top end.
