Intermittent start problems 2016 Ecodiesel
Jerryp
A victim of Harvey and high water. I have had the vehicle serviced with all fluids changed. Starter and alternator serviced. Lately I have had intermittent start problems. I turn key fob to start nothing happens. Wait a few seconds then it may or may not start. When it does start there the power seems just fine. This problem occurs with remote start also. Hasn't left me stranded yet because it has eventually started. Don't know if this in inherent to the Ecodiesel or something that I am experiencing.
Any help appreciated.
4,352
1,153
Welcome Jerry. Something electrical for sure.
Zachary
43
17
Assuming you had water to at least the frame, some important wire harnesses got submerged. The most critical connection is attached to the frame on the driver side toward the front (below driver door), it's large and you can't miss it. I would suggest taking a couple hours and crawling around under your truck with a lot of dielectric grease and packing every harness connection you find with it. You may have residual water causing increased resistance and over time corrosion will occur. I'd also spray any exposed metal with fluid film, it will help prevent rust but will need regular applications (every 2 years should suffice in Texas).
Sent from my SM-G900V using Tapatalk
Jerryp
Thanks, for some unknown reason the start problem has stopped. No problems since my original post
Zachary
43
17
That's good, I bet water evaporated and things are back to normal. I would still recommend packing those harnesses with electrical grease as a preventative measure against corrosion, that's usually the biggest long term flood damage issue.
