Hi Folks
Recently my low oil pressure warning light came on so immediately suspected that the oil pressure switch was defective. I replaced it but still had the same issue so I bought a Bosch mechanical gage to verify that the oil pump was okay. I had 5+lbs at idle and almost 30lbs at 1800rpm, so the pump is ok. A friend of mine is well versed in diesel so we started checking out other potential issues. Inside the oil filter housing assembly is a plastic of some sort, check valve, a spring with a ball (which is a pressure regulator, we think) and a vent tube on the outside. Called the dealer and the plastic tube is a non-serviceable part so you have to buy the whole housing assembly. Suspect that the plastic may be distorted and that is causing the low oil pressure issue.
After a week of searching…all over Canada and USA, only ONE housing assembly was available to buy, that dealer was in Alaska. This component is on back order everywhere with no eta on a ship date, so if you need one of those, good luck finding one. Does anyone have any other suggestions or ideas of what else could be causing the low oil pressure issue knowing the oil pump is okay??
Todd
Todd
