Ego diesel
- Sep 28, 2019
- 4
- 1
 - 2015
I I have a 2015 Ram EcoDiesel my mysterious coolant loss was due to the fact of one of the turbo cool lines underneath the intake you have to take the whole entire intake off even the plastic header with a swirl vents to get to this underneath there will be a line that has two banjo fittings on it that line wizard sleeves up and allows coolant to leak onto the top of the engine which steams off in the beginning but as it gets worse we'll start filling up the valley and splashing out on hard corners looking like somebody threw a 5 gallon bucket of coolant across the bottom of your engine the only way to fix this is to replace the hose it's a very short hose with two banjo fittings one on each side and a short piece of rubber hose that rubber hose breaks down from the heat I imagine it starts letting the coolant come out of it the only way to get to this line is through the top you have to strip it all the intake off of the engine to fix this the only way I saw it was because I was replacing the plastic header With A bank's metal header because the stock one was so full of s*** from the EGR that I had to replace the whole entire thing there was no way to clean it and then doing so I deleted capped off and reprogram computer also added another Turbo off of the EGR exhaust line and piped in a sequential extra Turbo while tuning to its Max abilities now my engine has over 500 horsepower and 700 foot pounds of torque it is complete Ripper and very quirky and strong with the four link stock traction bars that comes with the stability control makes this truck very very fast and stable after these mods have been completed good luck have fun and get a radar detector because you have tickets up the yin yang truck is very fun to drive a very stable at high speeds complete blast to drive now.
