Need some help
andrew93
Joined
Mar 26, 2023
Messages
Hey everyone I need some help I have a 2014 jeep with the EcoDiesel she was running rough last week code popped up p016f. Looked it up it said (CLOSED LOOP FUEL PRESSURE CONTROL AT LIMIT - PRESSURE TOO LOW) so I did the fuel filters and the fuel pump started sounding rough so put a new one in still runs a little rough and also have a bad knock coming for the driver side this knock wasn't there before I did the work any help would be much appreciated.
Remove the FCA on the CP4 and see if the FCA screen is plugged with debris!
Thanks for the reply. Did that think I figured out the problem the new fuel pump is a Chinese one and it's making a big knocking sound can't find a Mopar one right now because of a recall on the fuel pump.
Read a post yesterday where pumps from Amazon were causing the same problem. The answers were always a hit or miss with a none Mopar pump.
If its knock, it will be silent, after it explodes.... Still OP you need to remove the FCAs on both pumps and check for Debris ASAP.....
I will definitely check it again. Think it might be ok I've only driven 50km with the new pump but I'll check. Again I appreciate your reply.
Would you happen to have any suggestions on a good quality replacement pump
Yes.... Buy one form us TC Diesel.
