New ED engine
socalram
Spoke with the fleet manager at a ram dealership yesterday. He stated he was at a conference this past weekend where they stated the online training for the new ecodiesel engine is going to be available March 1. He assumes it should be available this summer.
I asked him if he’s heard any info as far as engine failure issues being fixed...he said he didn’t know what I was talking about and said the previous engine was strong from what he’s seen.... what’s your input in that comment?
522
136
5% of ecodiesel engines died an unnatural death. Its kind of like saying "the Chevy Vega is a fine car" back in 1975. Most problems were related to the oil being unable to lubricate the engine once the soot from the EGR got heavy in the oil. There were some causes such as people using mineral oil by using Jiffy Lube (etc.), some were from tuning the engine for more performance than they could handle, but most were legitimate lubrication failures in the engine. It had not been experienced in Europe because Tier 4 emissions standards are brand new in Europe and the engine had not been used with an EGR. We were lab rats!
CaptainMal
107
51
Failure rate is an unknown. Most were in the later 2014 to mid-2015 production range. Sure there were others but not as many as in those model years. The cause has never been released. Serious conjecture points to issues with assembly quality, bearing sources, assembly torque on rods and supply sourcing quality when demand hustled production up.
Sure the oil recommendation was changed from a 5-30 to a 5-40 synthetic but still, no proof that was a cure. The bad ones trashed themselves no matter what you put into them.
Today there are far fewer reports of major engine problems. Just guessing that most of the bad ones are gone now. Not sure that fleet manager knows or wants to report what he should know about the engines' history.
There are other problematic areas. Some turbo and EGR coolant seals have leaked, causing engine issues. In the upcoming Generation 2 engines that is supposed to be addressed along with crank, rod and piston changes. Hopefully the entire issue of cooling will also be addressed as the original ones tend to run hot when towing under load. Playing with the three-way valve and the thermal control valve on the transmission has often been required in an attempt to get cooler towing temperatures.
A good clean-running Ecodiesel, with EGR turned off, is really turning in some great fuel mileage and useful towing service. Many , like mine, are way over 100,000 miles and lots over 200,000 miles. The main secret is getting a good engine, keeping it clean with a program like GDE to turn off that EGR and quiet the DEF sensors. Then running and maintaining it properly.
522
136
I couldn't be happier with my engine and the GDE tune. Great mileage and never a problem. I did make a gasket out of FEL RAM to block off the EGR tube to make sure any coolant from a faulty EGR cooler couldn't make it to the intake. Until I am out of warranty I will keep toting around the extra weight.
720
Fleet manger? Hmmmm training....I suppose This So Called fleet manager knows what about the ED, My guess 1 level below the 1500diesel.com.
BRAD MILLER
81
13
AS MINE SITS IN A DEALER IN N.H. BLOWN AND THEY ARE TYING TO USE THE BANKS BULLET AND SILENCER TUBE AS THE CAUSE FOR THEM NOT COVER A REPLACEMENT AT 77,500 MILEAGE.........
720
I left message at TDR for Ya to call Me.
522
136
I got this off a discussion board but I would call Banks. No way that silencer tube does. that is nothing but a metal tube replacing a plastic tube.
Will Banks products void your warranty?
I have a psd, please no flames. I am considering a chip and exhaust but dont want to loose the warranty. I spoke with banks and they said their products do not void warranty. Is this crap or has anyone had experience with them coming to bat for you. I want to know if dodge were to void your warranty, would banks help you out. The banks guy said "we would call the dealership and get it resolved. What do you think?
BRAD MILLER
81
13
I CALLED BANKS,DIDN'T GET THAT ANSWER.DEALER STICKING BY ANY AFTERMARKET ADD ON PART VOIDS WARRANTY..... STILL EARLY IN THE FIGHT....
720
Get it out of that Dealer before its to late.....
522
136
There is such a high failure rate and so much documentation that 19 engines a week fail. Get a lawyer, file suit and settle. Big companies settle fast. The Banks bullet complicates matters. I am sure you wish you pulled it off before taking it in.
