oil issues
Wesley Lantz
I have a 2015 ecodeisel, I had the egr cooler go bad in may, I had since had it replaced. Now, the issue is I seen an oil leak near the front of truck, so I started looking and I found oil in the coolant reservoir, and little coolant, Maybe it was mixed. I also have an oil low pressure light. I have an appoiment for Friday and the dealership, anyone have this issue yet? any insight would be great
Brokedownbutgood
289
103
Your oil cooler failed, if the vehicle is out of warranty stop driving it.
Wesley Lantz
Well,the truck is still at the dealer. The oil cooler did in fact fail, putting oil sludge into the coolant system, and into the engine. they are trying to clean in out and are havjng to replace oil cooler, all the coolant lines, the radiator, and the heator core. no word on when it will be done. they said there is a possibility they will have to replace the engine. will let you all know the final outcome.
