P0128 but I can’t figure it out!
Big bubba
About a month ago my check engine light came on. I checked and it came back at p0128. My temperatures looked to be good, heat is still hot. So I turned the light off. About 10 days later it popped up again. So I turned it off and it’s now popped up for the 3rd time. Any ideas on what I should do? I know it’s a code for a thermostat but I don’t see the point of changing out something that appears to be working? Open to suggestions!
maple09pj
Hey there, wondering if you figured out your issue. I'm not much help but I have the same issue on my 2016, sometimes get P0128 and also sometimes get P01289. Truck seems to run fine and temp on gauge is normal. I changed the coolant temp sensor and the problem did not go away.
Big bubba
I couldn’t find my previous log in information so I made a new account. I changed the thermostat and it hasn’t been on for 500 miles now.
maple09pj
Hey thanks for logging back in and giving me that update. After seeing this I watched my coolant temps a little closer and mine was running a little low 80-85c. Changed the thermostat and it’s running 90-93c and no more CEL.
For anyone else doing the job make sure you have a 1/4” universal joint or wobble extension for your ratchet. The one bolt is at a bad angle. Tape your 8mm socket to the extension so you don’t lose it into the abyss. Undo the metal fuel line that’s in the way and it gives you a little room. No fuel will come out. Especially helpful when you’re reinstalling that bolt so you don’t cross thread.
Cheers!
Hotrod52
No all thermostats stick closed some remain open, the computer maybe looking for a certain temperature vs run time, if it does reach target in time sets the code.
