Pcm ground location?
Bgraham
I have power to the ecm/pcm/eps fuse 78 and fuse 22 ecm. But still have a no communication. I can scan all modules but the engine. The truck was running fine at lunch then when I got off work I had a no crank no start issue. I have checked all connections and load tested the battery, and all seems good. Also has a push clutch to start on the gauges but it's a auto. It's a 2015 Laramie tuned/deleted. I hooked up my sft tuner and it came to life long enough to load the original tune, then back to no comm. I have another pcm on the way, but thought I would post here incase some has had similar issues. THX
711
Did you check Big connection under Dash
711
Is the Battery fully charged... I have to ask...
Bgraham
Yes that was the first thought I had. Charged and load tested.
Bgraham
I also have another push button ignition switch and pcm in the way.
711
I'm not too familiar with the electronics of the VM 3.0 and Ram 1500, Do you have ALFA? How Many FOBs Do You have.
Bgraham
I recently got alphaobd and have 2 fobs. I have not tried the other 1, but will today.
Bgraham
So I just tested the pcm fuse f72 with a test light and it has ground going to it.
