I replaced crank position sensor it cranks but won’t start 2014 1500 ram Ecodiesel
R Rickyesco77 New Member Jun 8, 2019 2 0 Truck Year 2014 Jun 8, 2019 #1 I replaced crank position sensor it cranks but won’t start 2014 1500 ram Ecodiesel
T toyman New Member Nov 4, 2019 16 1 Truck Year 2015 Nov 4, 2019 #2 was wondering if you got it fixed and what the problem was I have same
C carlhenry Well-Known Member Nov 21, 2018 1,506 286 Truck Year Not Listed Nov 4, 2019 #5 did u check fuel pressure?
T toyman New Member Nov 4, 2019 16 1 Truck Year 2015 Nov 4, 2019 #6 checked crank sensor good has no injector pulse
C carlhenry Well-Known Member Nov 21, 2018 1,506 286 Truck Year Not Listed Nov 4, 2019 #8 u need at least 3500 lbs fuel pressures for the injectors 2 fire the ecm won't recognize them till the pressure is up try starting fluid and see if it fires
