Service Electronic Throttle Control
Fbagg
Hi, New to forum, Having my first issue with 2018 @ 51500 miles, stock ECU, from the republic of California so tunes to delete not an option especially since it’s a company truck. Today in a parking lot driving slow Service Electronic Throttle Control came on, can no longer “punch” throttle but can ease into it. Should I try EGR / MAP cleaning before I take somewhere? I do not have a scanner to clear code and am not looking forward to leaving my truck at a dealership before Christmas and New Years, any other suggestions?
4,366
1,158
Welcome! That's the dreaded code which seems to have multiple fixes. I'd start by the methods you mentioned, then searching around a bit on this forum as we've got TONS of info around this issue.
1,064
365
Harbor freight sells a scanner under 30$. Without a means of a scanner you could be chasing a ghost. You find the code you can 99.8% pinpoint the cause of the issue.
Fbagg
no one should b driving a eco that does not have a obd2 reader
Probably a good suggestion, do you have any recommendations? I’m not afraid of paying for a good one especially if it covers Ram / Chevy / Ford since we have all in our company fleet.
1,064
365
Fbagg
Do you have a recommendation on a good one that works for all the manufactures? I’m not afraid of paying for a good one that helps with all our vehicles in our fleet.
1,064
365
I got to it too quick lol check out my last post. I also use mine to connect to my laptop and use Alfaobd to see what dealers see and allows for a variety of procedures and tests to be run as the dealer can do.
Fbagg
Thanks I’ll check
Fbagg
Well here is my update :
Codes came up as follows. 1) P0402-00 EGR flow excessive detected 2) P2280-00 air flow restriction
So I changed air filter, and followed a video suggested elsewhere in this forum to remove and clean EGR tube and the MAP sensor, both had a lot of carbon build up. Cleared codes and have driven it several days now totaling about 300+ miles and everything was great. Until tonight as I’m coming home the service electronic throttle control came back, any thoughts?
