Shuttering and stalling… no codes
AyK
Hello all, about 6 months ago I was driving on the highway and I noticed for a split second as if I lost power while I was accelerating. The first complete stop I came to after that my truck shut off. Attempted to start it back up and it wouldnt start until it sat for a few minutes. I didn’t want to chance it so had it towed home. I kept it close to home and drove it around to see if I could get it to act up again, also no codes were thrown. It seems to shutter a bit at a lower speed and will stall from time to time once coming to a full stop. I’ve replaced the in-tank fuel pump, had the HPFP replaced, changed fuel filter, new MAF sensor, cleaned MAP sensor, new air filter, new gas pedal. Also dropped the oil pan to check for sludge but it was very clean and no signs of metal in the oil filter. Still having the same problem. Next I’m going to replace the crank sensor and tone wheel, but thought that would’ve thrown a code, shifting seems to be a bit off too. I have the weight reduction EOC for almost 2 years no issues until 6 months ago. 2014 with around 115k miles. Would appreciate any input. Thanks.
MRDIN
Were you able to figure this out? I’m having the same issues.
AyK
I have not. I’ve purchased a new tone wheel and crank sensor and I plan to tackle that next. I can let you know if that addresses it or not.
MRDIN
I’ve replace tone wheel and crank sensor to no avail , only thing I think may have been a mistake was buying an aftermarket sensor, so I’m going to get a dealer one next
1,057
363
Sounds like maybe torque converter isn’t unlocking. Does it seem harder to stop?
1,057
363
I would think if it was tone wheel, it would do it more than just lower speeds. Possibly hpfp not giving fuel pressure at lower rpm?
AyK
Not sure, but had the hpfp replaced already it didn’t change anything
MRDIN
I’ve sent my injectors out to be tested and have ordered new ones, on Monday I’ll let you know how that goes.
MRDIN
It wasn’t grenaded the truck ran the same as it does still. It was a possibility so had it replaced under the recall.
Have you had a chance to look at your total fuel consumption per cylinder?
allensgbt
Any luck solving this issue. I have a 2018 thats doing this exact same thing. I have changed the transmission, transfer case, supply pump, tone wheel and sensor, fuel filter, still doing it.
AyK
After changing tone wheel/crank sensor it was still doing it. I ended up getting rid of the truck after that. Problem solved!
