So many error codes
bammbamm1961
1st Eco (2016) was a Lemon Law buyback, then I replaced it with a 2017 and have had nothign but issues with Def, EGR Cooling Valces, now I am getting these codes (
P0420 - P200A. B - P2047 - P20E9 - P026C - U3017 - P2D2D, E) is there not a way to dismantle the BS systems - the engine is great, its all the controls and junk they layer that are causing me issues. Lastly I have a message saying my truck will be disabled (not limp mode, but shut down) without service. So If I am out the moab desert I will dry from dehydration ;-) ???
nstavros
My 2015 Eco now has 244,550 miles. The DPF went out (apparently) under code P0420. They've replaced it and then the DPF started smoking. They replaced it again and had to do some reprogramming. Well yesterday evening it started smoking again. I'm not sure if the DPF is at fault or something upstream causing the brand new DPF to fail. The dealer seems to be confused too as they've had to invite the Technical Advisor from FCA or Chrysler or whatever they're called these days.
  • IMG_9656.MOV
