Tone ring and CKP failure
Huot4
hey everyone, I own a 2016 Ram Ecodiesel stage 2 tune by SFT (I know they just closed up shop as of Dec 25, 2024). I just had my tone ring and CKP fail on me, and I've done the work myse4lf to replace the failed parts. now that everything is back together, I'm still stuck with a crank no start situation. has anyone else experienced this if so, how did you get the truck running again. I'm kinda limited on time as we had a tech at work take the week off which gave me time to swap the parts out after work hours, now IM just trying to get it out of the shop under its own power and not manpower
728
Do you have ALFA OBD II? or Equivalent? What's the RP, AND RPMs, if you have RP above 2200 PSI and reading RPMs then it a connection problem, Check every connection under the Hood and Dash.
1,057
363
Do you have any codes? Did the tone ring take out the sensor and if so was that replaced?
