Hi, new member here. I have done what Sean has done and the "lighting bolt" and check engine light are still lit. I can clear the codes but when I go to start the truck they come back on immediately.
The Tmap and the throttle charge air temp sensor are working properly. I bought factory new ones to confirm proper ohms since there is no mention anywhere of the ohms reading.
I also get the code PO 336(crank sensor). I know about the tone ring issue, I know that my warrantee as been extended. I have contacted the dealer and had them order the parts but they are 3-6 months out, could be longer.
I have two questions;
1) is the crank sensor and the turbo valve dependent on each other. Meaning if the crank sensor is not reading correctly, will that trigger the turbo valve issue?
2) I am looking for a FSM can't seem to locate one. I heard there is a CD but that's had to take out into the field. Any help on the service turbo valve and a FSM would be great.
Thanks.
Thanks.
