Vgt U010C code
Logan Hubbard
Hey All!
First off, thanks in advance. I have a 2018 ram eco diesel with 106k miles. Deleted, tune.
Anyway, I was under the truck after doing some brakes and noticed a section of old wires from that went to components prior to the delete well I was moving them and somehow one wire was exposed as I was pushing it up it sparked on the exhaust. Now I have that code with hardly any power. The vgt control module is apparently one with the turbo and I would have to replace both. Is there a way to test it before doing all that? Or any ideas or tricks to try?
Logan
1,249
341
Hey All!
Logan
I've got a good vgt actuator on the shelf, it kinda sucks but you can do it from on top of the engine. Just pop off the e clip and linkage, then it's a few 10mm.
As to the module for it I'm not sure. None of that should be powered circuits from exhaust sensors, in my opinion anyway.
Logan Hubbard
Thanks so much! If I wind up needing it I will let you know. This am I double checked every single fuse and I found a bad Ignition coil fuse. Problem solved. For now ... ha
