Whats the problem?
Blaine
Got a 2016 1500, 3.0 obviously. Won't run on remote start more than a few seconds, has lost a lot of coolant, and has a dtc p04db. Thanks in advance
1,068
367
Welcome! Sounds to me like you hve an intake problem but need a lot more info. How many miles are on it now and how many since you bought it? What’s your typical type of driving?
Blaine
98,000 miles. Typically just drive to work, about 20 miles round trip
1,068
367
P04db was a code I got after I tuned transmission. 20 miles round trip is borderline what these trucks enjoy. They do much better on the highway. But I would venture to say your egr hs failed and ruined the intake.
Blaine
Well FML
1,068
367
The egr has a recall on it so if egr is bad and it ruined manifold then your covered
1,068
367
How many miles ago was it done? There’s one user who has had his truck go up in flames even with the new egr
1,068
367
I wouldn’t be surprised to find that egr has failed. Also, some of the egr work if they failed was replaced with original style if the new style wasn’t available
734
If codes are triggered, the remotes start will engages and shutdown.
Blaine
Yeah, just got off the phone with a service tech, he said the same thing. Good news is I still have a warranty
734
Good , Stand Your ground Document everything.
Blaine, those 20 Miles City or Hwy?
734
You should be good. Just makes sure occasionally it can complete its Active Regen from start to finish.
