2015 pro master 2500/ 3.0 four cyl deisel. Can any one tell me the best way to clean the particulate filter, after it has been removed from the van?
PARTICULATE FILTER CLEANING
SLT
Can any one tell me the best way to clean the particulate filter, after removal from a pro master 2500?
Liqui Moly 5169​
I cleaned my 2017 Ecodiesel Ram with the Liqui Moly particulate cleaner. I flushed it afterwards with a Liqui Moly flush solvent. It restored the particulate filter. I drove the truck and it smoked for about 12 miles and then it cleared the particulate filter and it ran like new. I cleaned mine on the vehicle using a pumped up bug sprayer can. I just removed the DPFluid injector and stuck the cut-off end of the sprayer through that hole.
If you have the DPF filter off the truck, you can use a high pressure washer to clean it by spraying the water backwards through the filter to flush out the soot. If that doesn't work, try the Liquid Moly Flush, followed by another hi pressure washer spray down. Both need to be sprayed in to the rear of the DPF filter.
Snoopy
