2015 3.0 turbo lag
Cur
New to having diesel just seeing what everyone recommends for the turbo lag … should I just delete the egr and def? Or is there other options thanks for time
954
495
Get a tune. The emissions system has nothing to do with turbo lag
Cur
Ok I appreciate your advice and time
SeanPwnery
156
69
2nd the tune suggestion - that initial delay from a dead stop is actually programmed in. Post tune, it ceases to exist.
Cur
What are your thoughts on pedal com. Or something similar ? … ow what tune do you recommend that is good but budget friendly
Clint77
I have a Pedal Commander, works great and the truck is a lot more responsive.
Locomotive Breath
Get a tune. MRTuning is very good. I’ve run several tunes and I like MRTuning best. Also recommend their trans tune.
EGR causes the lag. Try unplugging the EGR and see the difference. You’ll get a CEL but it will run much better. Be sure the engine is off when you unplug the EGR to ensure it is in the closed position.
Cur
I appreciate the info thanks alot
SeanPwnery
156
69
Oh, since we're talking about pedal upgrades for the electronic throttle body - I did a review on a product I received a few weeks back - still running it every day in "Sport +" mode and makes the drive soooo much more enjoyable. This is paired with an SFT Stage 1 Tune.
