2016 EcoDiesel will not start
stephen.moore11100
My 2016 ecodiesel started on Monday 11/18/2024, i ran some errands and it started every time. I got to my kids school to pick them up and it died. I cannot get it to start again. Due to some info I received in another forum I tried replacing the fuel control actuator and it ran for about 15 seconds then died. I did a fuel pressure test to see what kind of pressure i was getting from the lift pump and it is around 62-64 psi. I use my scan tool and it shows that the commanded psi from the hpfp is 3900 to 4200 psi but all i get is 120 psi or so. What is the next step in fighting or what is going on?
Thanks in advance.
stellaram2018
Sounds to me like your HPFP went out. You take off and can check the lines to see if you have any metal in them. If the pump is only showing 120psi its a good bet that it went out. Bad thing is you would need to replace pump, lines, rails, and injectors. Diesel logic sells a kit for around$2600-2900 and comes with a pump failure kit that saves injectors and rail if it happens again
stephen.moore11100
This truck had the hpfp recall done before I bought it in April. When i pulled the fca to change it, there were no signs of contamination on it. It ran for 10-20 seconds after replacing the fca and showed good pressure on the fuel rail when it was running.
schrste
I've got a 2021. HPFP replaced under recall in January 2024. Have 79,600 miles on it. Fuel filter changed every time oil is changed. Developed intermittent start issue (extended crank) and week ago. Scan shows demanded FP at start is 3900 psi. Actual FP when cranking sits a zero, then hits 3900 when it starts. This was with warm engine. Increased RPM and actual follows demanded perfectly and engine is smooth.
Suspect intermittent FPR (end of fuel rail PN 0281007209). Ordered new and will replace to see if my problem replicates. Will advise.1000005124.jpg
schrste
Suspect intermittent FPR (end of fuel rail PN 0281007209). Ordered new and will replace to see if my problem replicates. Will advise.View attachment 4491
FCA is perfectly clean. Will install new Pressure Relief Valve when it gets here.
