4” lift pictures?
Ofishl1
93
That looks great...well done.
Clinter22
Nitto Ridge Grappler
285/65 20 tire is 34.8 tall n 11.5 wide
Wtsurpsn
4” BDS - 35” Toyo Open Country M/T’s
Nice looking truck! What kind of fender flares are those?
JohnnyMac
75
24
Readylift Sst 4in kit
Bilsteins all the way around, front set at 0
1. 5in Supreme Suspensions hubcentric wheel spacers
20in ION 181 Wheels
35x10 Nitto Ridge Grappler Hybrids (not loud at all)
Sent from my SM-N950U using Tapatalk
Hi, been a while since you posted this. Just checking to see how the SST is treating you. I bought one in January and was just getting ready to install it and I see now that ReadyLift says it's not designed for the EcoD. I called them and they said they haven't actually installed it on one, so can't officially give it a thumbs up and just recently put that note on their website. That being said, did you have any issues? How's the CV angles? From what I could find, all the suspension part numbers were the same for the Eco, V-6 and Hemi so should fit. Thanks!
**EDIT** Looks great BTW!
M.A.
46
I jest finished to install the 4” lift on my 2018 EcoDiesel. I opted for a 4” vs 6” for me it’s just enough high.
Here are the settings
4” SuperLift suspension Kit with 5,100 series Bilstein shocks ($1,490 on sale)
35/12.5 Nitto Ridge Grapple
20” Motto rims, -18 offset
after and before
M.A.
46
Looks great @M.A. ! One of the nicest lifted EcoDiesels I've seen.. It doesn't scream "overdone" and just has a nice stance to it.
Thanks, the nose it’s still lower after lift but with the Bilstein adjustable struts I can lift the front another 0.7”to 2.8”, I think another 2” will level it. I did all the job by myself, I’m not a professional mechanic, so if you have questions about the settings I will be more than happy to help.
Acer510
Love the stance and look of the 35s!
Just curious what kind of city and highway MPG do you get now vs when stock?
4,354
1,153
Not to speak for him, but you loose a solid 3+ MPG when lifting up 4+ inches. I did on my 11 Duramax.
M.A.
46
Yes, the MPG go down about 2.5 overall, bigger tire mean that you need to recalibrate the speed. You can drive without do that but the shipping point need to be update, it will stay to long in lowers gears and engine run on high RPM. This is what I get with my ED after lift. First I used a RC speed calibration tool, and than I redo it with the help from AlfaOBD app, $150 vs $100. There is a difference in shifting point setup between those two, with RC set up on 35 tires the mpg was better a lil but it show 4 mph lower than the real speed, so I redo it over AlfaOBD.
Operations
Hi I’m planning on a 4” lift for my ‘17 Ram 1500. I’m undecided on running 33” or 35” tires. If you’re running one of these set ups could you post pics to help me decide? Thanks!
I’m going with a 3” lift and 35’s.
M.A.
46
Here is my 4” lifted with 35, motto metal -18 offset rims
Acer510
MA. How wide are the tires/wheels? What are the measurements? I really like the stance. It’s high but not too high or over the top
M.A.
46
Here is a better look at stock and 4” lift with a extra 2” front for leveling
Acer510
Is this then basically a 6” lift? The 4+2?
Looks good. I want this exact setup. :)
M.A.
46
It’s a 4” SuperLift with front Bilstein adjustable struts (shocks) set it up to the higher level. Now the lift kit will not level the truck , after I installed with the struts in the stock ( lower) position the nose is still lower. I drove it about 1k miles since I lifted, the ride is awesome, I’m m more than happy with the settings.
The SuperLift is the most complete lift for the money.
Here is what I put it on;
Loft kit
SuperLift 4" Lift Kit For 2012-2018 Dodge Ram 1500 4WD Gas and Eco Diesel Models - with Bilstein Front Struts and Rear Shocks
Rims
Tires
RIDGE GRAPPLER Tires (217040) by Nitto®. 35X12.50R20,
Steps
NERF STEP - W2W W/O BED ACS (2 STPS)
GOOD LUCK
I paid $1.490 (on sale) with Bilstein 5100 front/rear, about $2.800 for the wheels ( MottoMetal and $500 for the side rails ( steps).
Acer510
Also where did you purchase the lift kit from? Everywhere I see it's almost $1860.
