Milvetmac
- Mar 25, 2020
- 69
- 12
- 2014
Engine cut off, whole Xmas tree lit up with a crank/no start... after the tow and a quick scan found 27 codes stored all for different things but what stood out was the crank sensor failure and after researching it I ended up having to pull the trans, slap a new reluctor wheel on it since it broke in the same fashion you see everyone else’s (magnet popped a 3/4” section off) and since I did all that I just replaced the sensor at the same time to alleviate doubling down on the job. Identifix calls for almost 6 hours, realistically it be done in about 3.5 but I did have to drill a 3/8” hole in the side to get the torque converter to line up again for reinstallation... for what it was it was a pricey job, about $415 bucks for both parts plus my time
Since then it’s been about 3 weeks and havnt has a problem since
