Ecodiesel Failures/EPA 3.0 FCA Emails Granted Public Access
721
Dwalker The ED does get the Oscar for Mileage but the LOM needs to be verified buy HC, Mine is surprisingly Accurate , but at times its 1-2MPG off.
Ronald Doupe
115
CFT Performance.com The part # is SKU-DF514B56, They come plane unfinished, mine is mat black power coat, looks factory installed I installed it per there instructions, I will also say I have no connection with this company, the part is made very well, took me 15 minutes to install, and works as stated so far
Just an update, now have just over 11000 miles, yes I know it doesn't get driver much, I drained the catch can, about a table spoon of oil came out that is good rather not have it in the intake, no cels ever looks like it works fine
Is the tablespoon of oil what was collected over 11,000 miles?
Brokedownbutgood
289
103
How much a catch can well catch depends on the usage of the vehicle. On mine this is what I drianed out of mine after 1800 miles and a long tow. Thats a lid off a spray paint can for reference.
That's quite a bit. I'm sure it will vary with usage but still wonder why Ronald only had a tablespoon after 11,000 miles. That's a huge difference. Seems you would have 5 more of the lids full in the same mileage. I wonder if it's more of a blow-back issue for some trucks?
Brokedownbutgood
289
103
Do you know why that is?
More blow by is created when you work the engine hard. There is also more air being moved through the engine so more moisture content. Plus the higher engine temps mean more can evaporate out the system. Multiple reasons why its good to work the engine hard from time to time and get it up to full temp.
Thanks. I never thought about the oil evaporating at higher temps.
Ronald Doupe
115
No not 11000 miles I installed it with about 6000 miles on it I think, I tow nothing just drive it more like a car than a truck, if I towed it would be a 6.7 Cummins, not a 3.0 Ecodiesel
Brokedownbutgood
289
103
The oil itself shouldn’t evaporate but the moisture and or fuel that gets in it. If your running a none synthetic oil the lighter molecules can evaporate off which leads to slugde and high oil viscositys. But knowone should be running dyno oils in these trucks.
