- Jul 14, 2016
- 2,537
- 725
- 2015
The whole settle is here https://www.ecodieselsettlement.com/content/dam/fcacourtsettlement/pdf/DOJ_Consent_Decree.pdf
As you read the pages form pages 80 + FCA is NOW ordered to report violations to the EPA, They are also ordered to monitor and implement
My guess the New software will have detection, So even swapping ECMs will not work if you return the vehicle for warranty repairs.
Subject to standard limitations that must be identified to Eligible Owners and Eligible Lessees, which may set forth exclusions like accident, abuse, neglect, or installation of noncertified parts, and applicable existing warranty provisions that will remain in effect, the Extended Warranty shall cover the cost of all parts and labor needed to repair the items listed below.
• Catalysts o Diesel Oxidation Catalyst / Diesel Particulate Filter (DPF) Assembly o Selective Catalyst Reduction (SCR) Catalyst
o DEF Injector o DEF Injector Controller
o DEF Storage Tank o DEF Delivery Lines
o DEF Concentration Sensor (2016 Model Year Ram 1500 and Jeep Grand Cherokee only) o DEF Supply Module, Pump, & Temperature Sensor Unit
• Parts of the Fuel System
o Fuel Injectors
o Fuel Rail
o High Pressure Fuel Line o High Pressure Injection Pump & Regulator Unit
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o EGR Temperature Sensor
o EGR Cooler bypass actuator
o Oxygen Sensors
o NOx Sensors
o Fuel/Water Separator Sensor o Intake Swirl Actuator Sensor
o Particulate Matter Sensor
o Mass Airflow Sensor
o Boost Pressure Sensor
o Crankcase Pressure Sensor
o Exhaust Manifold Pressure Sensor .
Throttle Valve
o Exhaust Temperature Sensor
• Throttle Valve
• Cylinder Head Assembly, Including Valves, Springs, Valve Spring Keepers, Valve Seats, Cam Bearing Caps, and Manifold Studs (Camshaft and other components of the assembly are not covered)
Additionally, the Extended Warranty shall cover the cost of any OBD Diagnostic Scan for malfunctions that trigger the OBD Malfunction Indicator Light (MIL), regardless of whether the malfunction is attributable to a part that is covered under the Extended Warranty.
o Fuel Injectors
o Fuel Rail
o EGR Cooler Tubes
o EGR Cooler
o EGR Valve
o Oxygen Sensors
o NOx Sensors
Throttle Valve
• Throttle Valve
