Glow Plug Replacement
Big_John
How hard is it to replace the glow plugs? I have the message and need to replace and want to do it before Winter, when they are really needed. I purchased some serious penetrating oil spray... I plan to park the truck, spray the tops of the insert/threads.... and let sit for a couple days, spraying once or twice again.....
Or, is one better to just let a shop attempt this work?
The last thing I want to do is break one off.....
Big_John
Also..... Is it better to try and spin those plugs out with a cold engine or a warm/hot engine?
BTdriver
153
65
Before you go changing out glow plugs, try moving the connector on the plug - twisting, push/pull, etc. Then reset the code and see if it comes back. All this does is ensure the electrical connection is good. I have had two separate glow plugs pop a code, I did this and the code never returned. The truck starts just fine, even in winter.
