Jpop0077
- Mar 13, 2023
- 24
- 9
- 2015
Sorry for the long post but I need some insight on this.
so my check engine light came on about two weeks ago with the message, see dealership, check DEF system. I went 1000 miles past my oil change interval and was in the parking lot with it running and message; low oil pressure flashed and truck shut off. Grabbed the wife’s car to run errands and grabbed a quart of oil. Threw it in and it started up and drove fine. A couple days later as I had went and got the oil change stuff I was at work driving into the parking lot and again it died, message said check scr system.
Ok, I’ve since changed the oil. Hasn’t started. One day it started and then shut off again with low oil pressure message. I’m 1200 miles from home without my computer so I ordered and changed the oil pressure and temp sensors located under the oil filter. Nothing, so I bought a cheap code reader. 6 codes
P0401, P204F, P20E8, P016F, P0087, P1292.
I’ve changed the fuel filter and cleaned the DEF injector, also pulled the ERG tube out of my manifold and cleaned the soot offf.
I’m thinking I need to delete the ERG valve and cooler as well as the DEF but I need to clear codes before I tune it.
I was hoping to clear codes and get it running. I cleared the codes and I still can’t get it to start, now I have codes pending. Can I somehow reset the ECM to clear everything to get it to start so I can get it back to my hotel, that way I can install the delete kit. Should I just install the delete kit because the EGR valve is causing this issue and needs to be bypassed? Then tune it later. Any advise would help!!! Thanks Jason Popkey
